Lock a deployment instance
- At the bottom of the Project Explorer, click the Study Information (
) button. - Select the study.
- Select the Deployment Setup tab.
- To explicitly lock a deployment instance, right-click a deployment instance, select Lock and Protect, then Lock.
- To unlock a deployment instance that you explicitly locked, right-click a deployment instance, select Lock and Protect, then click Lock.
