What is a baseline used for?
A baseline is a snapshot of all the components in a study. Validation creates the baseline.
A validation baseline is temporary until you make it public, either explicitly or by using it to create a deployment package. Subsequent validation jobs that you run create a new temporary validation baseline and replace the previous one. Only you can view, edit, or delete a temporary validation baseline that you created, or use that baseline in a deployment package.
