When can I create a deployment package?
When a validation baseline is free from errors and warnings, or if you have indicated that warnings can be ignored, you can create a deployment package from it. A deployment package is a ZIP file that contains:
- Metadata that describes the study and the files required to create the MedML for the metadata.
- Deployment options specific to the target application.
- A list of all files in the deployment package.
- InForm rule engine assemblies.
- Rule assembly and user-defined functions.
- Assemblies required to deploy the study.
You install the deployment package on the computer where the InForm server is running.
