A rule in InForm is deactivated
If you deactivate a rule in InForm, do one of the following in Central Designer before creating a new deployment package:
- Remove the rule from the study.
- Disable the rule.
- Change the triggering event to On Demand (Batch Mode).
Rule-related changes that you make in InForm are overridden when you install a new deployment package.
Before you can create a deployment package, you must specify deployment options for the study in the Study Editor. Deployment options indicate the target applications, format, and languages or locales for which the study is being designed.
