Saving a deployment package
- At the bottom of the Project Explorer, click the Study Information (
) button. - In the Project Explorer, select the Deployment folder.
- From the grid, select the deployment package to deliver.
- On the toolbar above the grid, click Save as.
- If you are deploying to InForm release 6.1 or later:
- In the Deployment options section, in the Deployment Start Delay field, specify a time in milliseconds to delay deployment.
- Select a deployment instance to which to deploy the study.
The Type and URL fields are populated with the deployment type and deployment URL for the selected deployment instance.
Central Designer does the following:
- Determines whether InForm needs to update the study workflow.
- Identifies rules that were deleted or disabled since the most recent successful deployment so that the rules in InForm can match what is in Central Designer.
- Click Save, and specify the location in which to save the deployment package ZIP file.
