Set up the InForm environment
You must create the InForm server and study before you use the automated deployment feature. For more information, see the InForm Study and Reporting Setup Guide.
Before you can perform automated deployments to InForm, you also must meet the following prerequisites:
- In Central Designer Administrator, roles must exist with the Create deployment request and Approve deployment request rights, and users must be assigned to these roles. For more information, see the Administrator Guide.
- Users assigned to roles with the Create deployment request and Approve deployment requests rights must be on the study team. For more information, see Set up study teams.
- The deployment instance to which the deployment will be performed must be set up. For more information, see Create a deployment instance.
- In Central Designer Administrator, configure the default deployment options for each type of deployment instance.
