How do I deploy an in-place revision?
You apply an in-place revision by deploying a package that contains the revision into InForm. In the Create deployment package wizard, you review the changes and confirm that you understand the implications of making in-place revisions before you can create a deployment package that contains in-place revisions.
Note: After you deploy a study that contains an in-place revision change to a LIVE deployment instance, Oracle recommends that you remove all IPR configurations for the study. You can delete the IPR configurations manually using the IPR Summary Editor, or you can configure the Central Designer application to do so automatically. For more information, see the Administrator Guide.
