Accept, unaccept, complete, close, or reopen a task
- In the Project Explorer, select a study object (study design, study element, study event, form, section, item, codelist, codelist item, mapping, data set, or data series).
- Click the Tasks tab, which appears at the bottom by default, and select a task.
Tip: If you don't see the Tasks tab, at the top left of the page, select View, and make sure Tasks is selected.
- At the top of the Tasks tab, click an action.
Task Editor dialog box - Option descriptions
The second tab that appears in the Task Editor dialog box depends on the type of task that is selected. For standard tasks, the dialog box has an Instructions tab, and for translation tasks, the dialog box has an Assignment tab.
Option
Description
Top toolbar
Accept, Complete, Close, Reopen, Unaccept
Accept, complete, close, reopen, and unaccept a task.
Top section
Study
(READ-ONLY) Study with the study object to which the task is attached.
Object Name
(READ-ONLY) Study object to which the task is attached.
Object Type
(READ-ONLY) Type of study object on which the task was created.
Created
(READ-ONLY) Date and time the task was created.
Requested By
(READ-ONLY) User who created the task.
Status
(READ-ONLY) Status of the task (Open, Accepted, Completed, or Closed).
Task Type
(REQUIRED.) Type of the task. An administrator defines task types in the Central Designer Administrator application.
Priority
(REQUIRED.) Priority of the task. Options are Critical, High, Medium, and Low.
Due
(REQUIRED.) Deadline for when the task must be completed.
Default value—Current date and time.
Owner
(READ-ONLY) Person or team to which the task is assigned.
Completed By
(READ-ONLY) User who completed the task.
Completed Date
(READ-ONLY) Date and time the task was completed.
Instructions tab
(Appears for standard tasks only)
Instructions text field
Text for the task.
Assignment tab
(Appears for translation tasks only)
[List of roles]
List of roles to which the task can be assigned. If an administrator specified a default role to which the task type is assigned, the role is selected.
Note: Use the buttons on the toolbar to add an attachment and format the text.
