Create a data mapping
You can create a data mapping when you design your study to define what your data will look like. You can create data mappings in both studies and libraries.
- At the bottom of the Project Explorer, click the Data Mappings (
) button. - In the Project Explorer right-click a mapping folder and select the option shown:
- For Rule Mappings, select New Rule Mapping.
Mappings definitions are not generated or validated.
- For CDD Mappings in the InForm Mappings folder, select New CDD Mapping.
Mappings are generated and validated for a Customer-Defined Database.
- For CIS Mappings in the InForm Mappings folder, select New CIS Mapping.
Mappings are generated and validated for synchronizing between the InForm application and the Clintrial application.
- Enter the Title, RefName, and Description.
- Click OK.
You can now create a data set in the data mapping.
