Previous Topic
Next Topic
Book Contents
When should I use a data mapping and when should I use a rule?
If you need to create a rule on a study object, such as a form, but an item that the rule must reference is not in the scope of the study object, you have the following options:
There is no set guideline for which approach is better. The Central Designer application does not require you to use data mappings for rule creation, and you must weigh the benefits and limitations of using data mappings when making this decision.
Send Feedback
