Modify labels of mapped custom data dimensions
When you add an item to a data series in a data set with a custom data dimension, you are prompted to select a value for the custom data dimension and the data mapping. You can change the value at any time.
- At the bottom of the Project Explorer, click the Data Mappings (
) button. - In the Project Explorer, select a data series.
- In the grid, right-click an item and select Modify labels.
- From the Labels drop-down list, choose a codelist label for the custom data dimension. Optionally, depending on how the custom data dimensions were set up, you might be able to provide a user-defined label in the Labels field.
Note: If you type a label or modify an existing label, a new codelist item is created for the codelist.
- Click OK.
