Unmap an item mapping with a data series
When you unmap an item in a study, the item is no longer part of the data series for the study, but it is still part of the data series in the library in which it is saved.
You can restore an unmapped item if you want the item to be part of the data series for a study.
- At the bottom of the Project Explorer, click the Data Mappings (
) button. - In the Project Explorer, select a data series.
- Right-click the item, and select Unmap the Data Series.
The mapping between the item and data series is removed, and the value in the State column changes to Unmapped for the item.
