Modify CDD date time part data mappings
You can set up CDD data mappings for date time items so that:
- The entire date appears in a single database column in the CDD.
Each date time part appears in a separate database column in the CDD. The data mappings that the Central Designer application generates include the SPLITDATE attribute of the TARGETCOLUMNTYPE tag.
- At the bottom of the Project Explorer, click the Data Mappings (
) button. - In the Project Explorer, select a data series.
- In the grid, right-click and item and select Modify data point date part.
- Select one of the following:
- All in one column—Changes the data mapping from multiple columns to one column.
- Split columns—Changes the data mapping from one column to a column for each date time part.
- Click OK.
