Previous Topic
Next Topic
Book Contents
How do I set up CIS data mapping for date time items?
The following table describes how to set up a CIS data mapping.
CIS data mapping setup for date time items
Clintrial database result
Data series and data mapping setup
Entire date appears in a DATE database column. The DATE data type corresponds to the Oracle DATE database format.
  1. In the Item Editor for the date time item, select the Required and Allowed checkboxes for each date part.
  2. Map the date time item to a data series with a type of Date Time.
Entire date appears in a DATETIME database column. The DATETIME data type corresponds to the Oracle DATE database format.
  1. In the Item Editor for the date time item, select the Required and Allowed checkboxes for each date and time part.
Entire date appears in a TEXT database column. The TEXT data type corresponds to the Oracle VARCHAR(n) format.
  1. Map the date time item to a data series with a type of Text.
  2. In the Date-Time Data Point dialog box, select All in one column, and click OK.
Each date time part appears in a separate TEXT database column. The TEXT data type corresponds to the Oracle VARCHAR(n) format.
  2. In the Date-Time Data Point dialog box, select Split columns.
  3. In the CIS Date Part list, select the date time part to map, and click OK.
  4. Repeat these steps for each date time part. Place each date time part in a different data series.
Each date time part appears in a separate FIXED database column. The FIXED data type corresponds to the Oracle NUMBER(n) database format.
  1. Map the date time item to a data series with a type of Integer.
Send Feedback
