What are the custom property settings and design rules for custom context panels?
Design considerations for a custom context panel
Design consideration |
Custom property settings |
Design rules |
Data set |
Panel Type—Context panel. |
A data mapping can have only one data set for which the Panel Type value is Context panel. |
Data series for: |
A context panel can have only one block key item. |
A context panel can have only one page key item. |
Data series for the following key items for repeating visits and forms: |
A context panel can have only one block repeat key item. |
A context panel can have only one page repeat key item. |
Additional data series |
Context Type—Other context item. |
Use for additional data points to be collected for every record. Note: Data series with a Context Type of Other context item are designed to be used in hybrid studies in which users can enter data using either the Clintrial or the InForm application. When you deploy a study that contains a data series with a Context type property of Other context item, the item definition for that data series is created in the Clintrial context panel, but the CIS application does not synchronize data from the InForm application to that context item. To enter data into a context panel item that is defined using the Other context item Context type property, users must use the Clintrial Enter module. |
Context Type custom property |
Data series data type |
