ModifyCIS date time part data mappings
You can set up CIS data mappings for date time items so that:
- The entire data appears in a single database column in the Clintrial database.
Each date time part appears in a separate database column in the Clintrial database. To split data mappings for a date time item into date part components, you define a separate data series and mapping for each date part. The data mappings that the Central Designer application generates include the DATEPART attribute of the CTITEM tag.
- In the Project Explorer, select a data series.
- Right-click an item, and select Modify data point date part.
- To change the data mapping from multiple columns to one column, select All in one column.
Or:
To change the data mapping from one column to a column for each date time part:
- Select Split Columns.
- In the CIS Date Part list, select the date time part to map.
- Click OK.
