How are data mappings generated for specialized Clintrial panels?
The setting of the Panel Type CIS customized property for data sets determines how data mappings are generated for specialized Clintrial panels.
CIS data mappings for specialized Clintrial panels
Panel Type value |
How panel is used |
What is included in CIS data mappings |
Context |
Contains context items, which are included in every record in a clinical data table. The context items form the primary key of the clinical data record. |
Note: A data mapping can have only one data set with a Context panel type. |
Enrollment |
Contains screening and enrollment data for each study subject. The Clintrial application does not use separate records for screening and enrollment data. |
Non-Patient Data |
Contains data that is not related to a particular subject or visit, such as standard coding thesauruses, view codelists, or laboratory normal ranges. |
If selected, the Central Designer application generates data mappings for a non-patient data panel that has a column for each data series in the data set. Note: The data series in a non-patient data set must not have any items mapped to them. |
