Add an item to a data series by selecting a data series
- At the bottom of the Project Explorer, click the Data Mappings (
) button. - In the Project Explorer, select one of the following:
- Rule Mappings
- InForm Mappings > CDD
- InForm Mappings > CIS
- Select a data series to display the items in the grid.
- Select the Add To tab.
- Do one of the following:
- In the Filter field, type a keyword.
- Click Advanced Filtering.
- Specify the properties on which to apply the filter.
- Specify the display format for the filtered results.
- Click Refresh Results (
The item is added to the data series.
- If you selected a data series that has custom dimensions, select the custom data dimension to use, and from the Labels drop-down list, choose a codelist label for the custom data dimension. Optionally, depending on how the custom data dimensions were set up, you might be able to provide a user-defined label in the Labels field. Click OK.
Note: If you type a label or modify an existing label, a new codelist item is created for the codelist.
- Optionally, add more items to the data series.
