Subject_PastDrugHistory data set
in the Subject_PastDrugHistory data set
Data Series Title |
Description |
Location in Argus Safety |
PastDrugHistory_DrugName |
Name of a drug previously taken but not used concomitantly and not potentially involved in the adverse event. |
Case Form / Patient / Other Relevant History / Description |
PastDrugHistory_StartDate Time |
Date when the previously taken drug was started.
Case Form / Patient / Other Relevant History / Start Date |
PastDrugHistory_EndDate Time |
Date when the last dose of the previously taken drug was given. |
Case Form / Patient / Other Relevant History / Stop Date |
PastDrugHistory_Drug Indication |
Reason for taking the previously taken drug. Map to the user-entered verbatim or to the encoded MedDRA lower-level term. |
Case Form / Patient / Other Relevant History / Indication |
PastDrugHistory_Indication MedDRAVersion |
Version of MedDRA used to code the indication if the indication is mapped to a lower-level term. |
For items to be encoded in Argus Safety, MedDRA version is required by the format used for transmitting data but does not appear in Argus Safety. |
PastDrugHistory_Drug Reaction |
Adverse event experienced when taking the previously taken drug. Map to the user-entered verbatim or to the encoded MedDRA lower-level term). |
Case Form / Patient / Other Relevant History / Reaction |
PastDrugHistory_Reaction MedDRAVersion |
Version of MedDRA used to code the indication if the indication is mapped to a lower-level term. Note: If reaction is mapped to a text field entered by the user, do not map this field. |
For items to be encoded in Argus Safety, MedDRA version is required by the format used for transmitting data but does not appear in the Argus Safety. |
