About publishing, republishing, and unpublishing
You must publish study objects that were created in a library to allow users to search for them in the Libraries Browser. You can publish, republish, and unpublish study objects only in a library. You must save a study object before you publish or republish it.
In a library, you can publish any of the following.
Study objects that you can publish
What to publish |
Notes |
A single study object. |
When you publish a study object, you publish its most recent version or revision. |
A study object and its child study objects. |
All study objects. |
Tip: To prevent users from finding study objects using the Libraries tab, unpublish the study objects.
