Delete a task or collaboration note
Consider deleting tasks that were created in error or that are no longer relevant. Tasks provide an audit trail for assigned activities, so you should not delete tasks if you want to maintain an audit trail of assigned activities.
Note: Only the creator of a task or a user with the necessary rights can delete a task.
Tip: If too many tasks appear on the Home Page, use filters to reduce the number shown. For example, view only Open or Accepted tasks.
- In the Project Explorer, select a study object (study design, study element, study event, form, section, item, codelist, codelist item, mapping, data set, or data series).
- For tasks—On the Tasks tab, select a task.
For collaboration notes—On the Collaboration Notes tab, select a collaboration note.
- Click Delete.
- At the confirmation message, click Yes.
