Disable a workflow rule
To disable a workflow rule, you disable the workflow the rule is associated with.
- At the bottom of the Project Explorer, click the Visit Schedule (
) button. - Select a study design, study element, or study event.
- Select the Workflow Diagram tab, and click Disable Workflow.
