Previous Topic
Next Topic
Book Contents
Check rule syntax
Check rule syntax to ensure that the code in the rule expression is written correctly.
  1. In the Project Explorer, select a form, a form template, an item, an item template, or an item type.
  2. Select the Rules tab.
  3. In the grid, select a rule, and click Check Syntax.
  4. Select Show Errors.
  5. At the bottom of the Rules tab, in the Rule Summary section, resolve any reported errors.
Send Feedback
