Previous Topic
Next Topic
Book Contents
Run test cases
When you run test cases, the syntax of the selected rules is checked.
Note: To skip a written test case, select the test case, open the Test Properties tab on the Run tab, and set the IgnoreTest property to True.
  1. In the Project Explorer, select a study design (in a study only), study element, study event, form, section, or item.
  2. Select the Rules tab.
  3. Optionally, to see the rules' child rules click Show Child Rules.
  4. Select a rule, and click Rule Tests.
  5. Select the Run tab.
  6. In the list of rules on the left of the Rule Test Cases dialog box, select the test cases to run.
    Tip Tip: To select all test cases for a rule, select the rule. To select all rules and test cases, right-click the tree and select Check All.
  7. Click Execute Tests.
    Note: To run test cases for a rule that references third-party code (for example, ODP.NET), the referenced third-party components must be installed on the client computer.
  8. If the syntax check succeeds but the rule compilation fails do the following:
    • Attempt to resolve the errors.
    • Validate the study, and attempt to resolve the errors using the error messages generated by the validation.
    • Make sure that any review states you have defined for the study are complete.
Send Feedback
