How do I develop a study across multiple locales?
You specify the default locale for a study in Central Designer. Localizable study metadata is saved according to the default locale.
Language in which to type text values
You can enter item questions, labels, and text strings in any language, regardless of the default locale for the study. However, in some places, such as a form's Design tab, you can enter labels and question text without specifying a locale. In these cases, the default locale determines the language or locale that is assigned to the entered text. If the default locale is not included in the list of supported locales for the study, the entered text is saved for the locale but is not deployed. Only the supported locales for the study are deployed.
Typing text values using an explicit locale
If you work on a study with a locale that is different from the default locale, you can enter a study object's properties with an explicit locale. See the following table for places where the default locale is used and where you can specify an explicit locale.
Study objects and the default locale
Study object |
Property |
Specify a value in the default locale here |
Specify a value in an explicit locale here |
Study event |
Title |
Study Event Editor > General tab |
Short Title |
Form |
Short Title |
Study Forms Editor |
Form Editor > General tab |
Form Title |
Not available. |
Form Editor > Layout tab |
Item |
Question |
Item Editor > Design tab |
Short Question |
Caption |
Not available. |
Codelist item |
Label |
Codelist Item Editor > Languages tab |
Rule components and the default locale
Rule component |
Query text |
Not available. |
Query Action dialog box. |
Subject or Message |
Not available. |
Email Action dialog box. |
