What are the limitations on triggers?
Compound item—When a data change item trigger is set within a compound item, the trigger occurs when any items within the compound item gets edited.
Visit state triggers—These triggers (Frozen, Locked, Complete, and SV Complete) occur only when all expected forms in the visit have been started. Visit state should match the state in the InForm application.
Float data type—When a codelist value is float type and it includes decimal point with zero (.0), decimal point with zero (.0) cannot be included in the CODELISTVALUE column in the PFEX_ITEMTRIGGER table. Use an integer in this instance. For example, for 12.0, use 12.
Repeating instance output—Displays only the instance that triggered the output.
