How should I name my rules?
You are not required to use a naming convention for rules, but conventions can help you distinguish one type of rule from another and avoid duplicate RefNames. If you want to adopt a naming convention, consider prefixing rules with the following:
- wr - workflow rule
- gc - global conditions
- rul - data-entry rules (for example, rulDMConsDtCompare)
