Download and import an archived study or project
You can import an archive into the database in which it was created or into another database. You cannot import an archived study, study project, or library project if it still exists in the target database—first you must delete the existing study, study project, or library project.
Before you can import an archived study or project, you must download it from the database. Optionally, you can delete the file from the database after downloading it.
To download an archived study or project:
- (Optional) Perform a full database backup.
- In the Project Explorer, right-click a study, study project, or library project, and select Archive, then View Archives.
- Select an archive, and click Download.
- Click Yes to delete the archive permanently from the database, or click No to leave the archive in the database.
- Navigate to a location for saving the archive, modify the file name as necessary, and click Save.
- Click Close.
To import an archived study or project:
- Download the archive file from the database.
- To import a study, open a study project. To import a study project or library project, close the project in which you are working.
- Do one of the following:
- Right-click a study or study project, and select Archive, then Import Archive.
- Right-click the library project, and select Archive, then Import Archive.
- When the Import from Archive wizard appears, click Next.
- On the File Location page, click Browse, and navigate to and select the file to import.
- On the Archive Contents page, click Next.
- Click Finish.
If you imported a study, the project is reloaded. If you imported a project, you can open it by selecting File, then Open.
