Data Entry Rule Actions report
The Data Entry Rule Actions report runs at the study level. The report lists each data-entry rule action/locale combination in a study. Each row in the report corresponds to a supported locale for a unique rule action. For example, if a data-entry rule has two actions and two supported locales, the report would display four rows for that rule. This report does not include data for workflow rules or global conditions. The selected study must have at least one defined locale for this report to run.
The report displays each rule only once, regardless of the number of times that the study object on which it exists is used in a study. For example, a rule that is defined on an item that appears on more than one form appears once in the report.
Note: This report contains InForm-specific study objects and is not available for studies that do not have InForm selected as one of the Deployment Systems or contain only non-InForm study objects. When you generate a report for a study that contains an invalid workflow, an error occurs, and the report cannot be run.
Running this report should not be considered a substitute for validation. Errors (or lack thereof) encountered while generating this report are not necessarily a reflection of study validity.
Note: This report runs against data in the database. Oracle recommends that you save the study before running the report.
Fields in the Data Entry Rule Actions report
Field |
Description |
Action Expression |
For SetValue expressions: The expression that you create in the SetValue Action box. For Update Workflow actions: UpdateWorkflow(). |
Action Type |
Type of action, such as Query or SetValue, that occurs upon evaluation of the rule expression. |
Email Sender Email Recipient Email Subject Email Body |
(Applicable for Email actions only.) The following information about the email that is sent upon evaluation of the rule expression:
Error Message(s) |
Description of the error(s) encountered while gathering data for the data-entry rule action/locale combination represented in this row. |
Error status icon |
Indicates whether an error was encountered while gathering data for the data-entry rule action/locale combination represented in this row.
Locale |
Locale in which translated text appears for the action. Translated text appears in the following fields:
Query Status Query Text |
(Applicable for Query actions only.) Status and text of the query that is created upon evaluation of the rule expression. |
Rule Description |
Description for the data-entry rule. |
Rule Last Update User |
Name of the user who most recently updated the data-entry rule. |
Rule Match |
Selection in the Rule Wizard > Actions > If the value is section. For example, Always. |
Rule Name |
Name of the data-entry rule. |
Rule Revision |
Revision number of the data-entry rule. |
Rule Status |
Status of the data-entry rule; either Enabled or Disabled. |
Rule Switch |
Expression for the data-entry rule. |
Rule Timestamp |
Date and time when the data-entry rule was most recently updated. |
Rule Trigger |
Event that causes the rule to run; either FormSubmission or OnDemand. |
Rule Type |
Type of rule; either Intrinsic (for a rule created based on a rule template) or Expression (for a calculation or constraint rule). |
Study Object RefName Study Object Title Study Object Type |
The following information about the study object on which the data-entry rule exists:
Target Form Mnemonic Target Form RefName |
Short title and RefName of the form on which the item that is the target of the rule action exists. Note: If the item is used on multiple forms in the study, the mnemonics and RefNames for the forms are listed and separated by semicolons. |
Target Item Number Target Item Question Target Item RefName Target Item Title |
Number, question, RefName, and title of the item that is the target of the rule action. For example:
This information does not apply to UpdateWorkflow actions. Note: If the item is used on multiple forms in the study, the item numbers for the forms are listed and separated by semicolons. Note: When an item appears on only one form and is in a repeating section, therefore ending in zero, such as 2.10, the number in the Target Item Number column is enclosed in single brackets, such as '2.10'. |
