Protect and unprotect a library
- At the bottom of the Project Explorer, click the Library Information (
) button. - Right-click the library and select Protect.
The icons to the left of the library and all of the study objects within the library change to reflect a protected status.
Note: You cannot delete study objects that are the direct children of a protected study object. After you protect a study object, you cannot select Undo, but you can select Unprotect.
) button. - Right-click the library and select Unprotect.
The icon to the left of the library changes to reflect an unprotected status.
Note: Unprotecting a library or a study object in a library does not affect study objects that you copied from the library into a study.
