What information is imported from an archive?
Information that is imported from an archive
Component |
Information that is imported |
Attachments |
Attachments on:
Files with the same name are overwritten. |
Baselines |
All baselines. |
Categorizations |
Note: If categories or keywords already exist in the target database, they are not overwritten. |
Collaboration notes and tasks |
All collaboration notes and tasks in the study, study project, or library project. |
Custom properties |
Note: If custom properties with the same name and on the same study object already exist in the target database, they are not overwritten. |
Functions |
All functions in the study, study project, or library project. Note: Functions with the same file name in the target database are overwritten. |
Study objects |
Note: The identifiers for study objects are maintained after an import. Linked study objects are overwritten in the target database only if the archive contains a newer revision of the study object. |
Validation results (Studies only) |
All validation results. |
Notes:
- The units file is not imported. If you need to recover this file from an archive, contact Oracle Services.
- Users and teams are not imported. When study objects in the archive refer to a user that does not exist in the target database, archiveimporter is inserted for the user's name. For example, if the user JohnSmith modified a study object in the archive but does not exist in the database, the History Viewer lists archiveimporter in place of JohnSmith after the archive is imported.
