Generate an Annotated Study Book
Note: In the Annotated Study Book and Form Preview window, if a row contains many components, the browser that displays the page might wrap text to fit all components onto the page. Consequently, for Asian languages, a wrapped text label might appear to have vertical orientation, with a single character on each line, because the browser wraps text on a word boundary, and a single character can represent a word. To compensate, you can make the question portion of the row smaller so the labels in the control section are wide enough not to wrap.
- At the bottom of the Project Explorer, click the Study Information (
) button. - Select the study.
- In the upper-left corner, click File, then Annotated Study Book Options.
- Select display and cover page options.
- Click OK.
- In the upper-left corner, select File, then View Annotated Study Book.
- If the deployment properties of the study include more than one locale or layout format, or the Annotated Study Book includes an In-place Revisions Summary table and the study contains in-place revision objects with IPR configurations for one or more deployment instances, the View Annotated Study Book dialog box appears.
- In the Layout and Language fields, select the name of the layout and a locale.
Note: The language setting that you specify when generating an Annotated Study Book and the locale setting that you specify when generating a deployment package for InForm are independent and can produce different results.
- In the Deployment instance field, select the deployment instance for which to display the IPR Summary table.
- Click OK.
When you generate an Annotated Study Book with a Schedule of Events table, and the study contains an invalid workflow, an error message appears in a dialog box and in the Schedule of Events table, and forms are listed in the Annotated Study Book in alphabetical order regardless of the selected order. When this occurs, the option to save the Schedule of Events table as a CSV file is disabled.
For more information, see Annotated Study Book Options dialog box.
