What does the Custom Events table in the Annotated Study Book contain?
Field |
Description |
Title |
The title you gave the custom event. |
RefName |
The custom event's RefName. The RefName corresponds to the Custom Event Name in InForm Publisher. |
Description |
The description you gave the custom event. |
Integration type |
The integration type that you selected for the custom event. Integration types are added in the Central Designer Administrator. |
Destination name |
The destination application where InForm sends the exported data. |
Endpoint name |
The endpoint name corresponds to the Endpoint Alias in InForm Publisher. |
Active |
The custom event's active status. |
Evaluate on |
Indicates whether to run the custom event against new data only, or new data and existing data. |
Priority group |
The order to run the custom events in. |
Prerequisite |
The name of the custom event that needs to run before the current custom event can be triggered. |
Trigger operator |
Trigger data |
Trigger type |
Subject or study object the custom event trigger is created on. |
Mapped object path (RefName) |
The RefName path of the study object that you created the custom event trigger on. |
Event type |
The type of event that causes the custom event result to be triggered. |
Additional values |
Information in addition to the event type that you entered for the trigger. |
Result data |
Result type |
The type of data you want to export when the custom event is triggered. |
Map to name |
The destination where you want to save the exported data. |
The RefName path of the study object whose data you want to export when the custom event is triggered. |
Custom data |
The additional data that you want to export when the custom event is triggered. |
