Format dates on the Annotated Study Book for the Japanese locale
For studies developed in the Japanese locale, the long date format is used to format the dates (Generated Date and Sponsor Date) that appear on the cover page of the Annotated Study Book.
Optionally, you can customize the long date format in the following way:
- On your PC, open the Control Panel and select Region and Language Options.
- Click Region and Language.
- In the Format drop-down list, select Japanese (Japan).
- In the lower-right corner, click Additional Settings.
- On the Date tab, in the Long date drop-down list, select a formatting option.
- Select the Time tab and select a Time format.
- Click OK, then click OK again to close the Control Panel.
- Generate the Annotated Study Book for the Japanese locale.
The dates on the cover page match the configuration that you specified in the Control Panel.
