Make repairs to the study
- On the Baselines tab, view the messages for the validation baseline.
Tip: If you don't see the Baselines tab, at the top left of the page, select View, and make sure Baselines is selected. - Review the Description for each message for which the Validation Type is Internal Error.
Note: To view the complete text of a message that is truncated because of column size, hold the cursor over the portion of text that is visible. Alternately, select a row, and then right-click it and select Properties.
- Right-click the error or warning.
- Select Repair Study.
- To start the repair, click OK.
Note: You cannot undo this action.
- If all the issues are resolved or Central Designer doesn't find any issues, click OK.
If the study repair tool cannot resolve all issues, save a copy of the event log and contact Oracle Support.
Tip: You can run study repair any time you want from the Tools menu.
