Subject_AdverseEvent data set
in the Subject_AdverseEvent data set
Data Series Title |
Description |
Location in Argus Safety |
AE_VerbatimTerm |
Symptom or description of the adverse event as entered by the InForm user. Required. |
Case Form / Events / Event Information / Description as Reported |
AE_LowLevelTerm |
MedDRA lower-level term (LLT) for the adverse event or reaction. Note: Do not map this data series if the item will be encoded in Argus Safety. |
Case Form / Events / Event Encoding / Lower Level Term |
AE_PreferredTerm |
MedDRA preferred term (PT) for the adverse event or reaction. Note: Do not map this data series if the item will be encoded in Argus Safety. |
Case Form / Events / Event Encoding / Preferred Term |
AE_LLTMedDRAVersion |
Version of MedDRA that was used to code the verbatim term to the lower-level term. Note: Do not map this data series if the item will be encoded in Argus Safety. |
For items to be encoded in Argus Safety, MedDRA version is required by the format used for transmitting data but does not appear in Argus Safety. |
AE_PTMedDRAVersion |
Version of MedDRA that was used to code the verbatim term to the preferred term. Note: Do not map this data series if the item will be encoded in Argus Safety. |
AE_TermHighlightedCode |
Term highlighted by the reporter (for example, highlighted as serious, highlighted as not serious, serious and not highlighted, not serious, and not highlighted). |
Case Form / Events / Event Information / Term Highlighted by Reporter |
AE_StartDateTime |
Onset or start date of the adverse event. |
Case Form / Events / Event Information / Onset Date/Time |
AE_EndDateTime |
End date of the adverse event. |
Case Form / Events / Event Information / Stop Date/Time |
AE_FirstDoseToOnset Duration |
Duration between the first dose of the study drug and the onset date of the adverse event if exact tart and end dates are not known or the duration is less than one day. |
Case Form / Events/ Event Information / Onset Latency |
AE_FirstDoseToOnsetDuration Unit |
Unit for the first dose to onset duration (Minutes, Hours). |
AE_LastDoseToOnset Duration |
Duration between the last dose of the study drug and the onset date of the adverse event if exact start and end dates are not known or the duration is less than one day. |
Case Form / Events/ Event Information / Onset From Last Dose |
AE_LastDoseToOnsetDuration Unit |
Unit for the last dose to onset duration (Minutes, Hours). |
AE_OutcomeCode |
Outcome of the adverse event at the last observation (for example, Recovered, Fatal). |
Case Form / Events/ Event Information / Outcome of Event |
AE_SeverityCode |
Severity of the adverse event (for example, Severe, Moderate, Mild). |
Case Form / Events/ Event Information / Event Intensity |
AE_HospitalizationStart DateTime |
Date that the patient was admitted to the hospital as a result of the adverse event. |
Case Form / Event / <event name> / Seriousness Criteria / Hospitalization / Details / Start Date |
AE_HosptializationEnd DateTime |
Date that the patient was discharged from the hospital after having been admitted as a result of the adverse event. |
Case Form / Event / <event name> / Seriousness Criteria / Hospitalization / Details / End Date |
AE_InterventionRequired Indicator |
Indicates whether the adverse event required intervention. |
Case Form / Event / <event name> / Seriousness Criteria / Intervention Required |
AE_Duration |
Duration of the adverse event if exact start and end dates are not known or if the duration is less than one day. |
Case Form / Events / Event Information / Duration |
AE_DurationUnit |
Unit for the duration of the adverse event. |
AE_SeriousnessDeathIndicator |
Whether the adverse event resulted in death. |
Case Form / Event / <event name> / Seriousness Criteria / Death |
AE_SeriousnessLifeThreatening Indicator |
Whether the adverse event was life threatening. |
Case Form / Event / <event name> / Seriousness Criteria / Life Threatening |
AE_SeriousnessHospitalization Indicator |
Whether the adverse event resulted in hospitalization or prolonged existing hospitalization. |
Case Form / Event / <event name> / Seriousness Criteria / Hospitalization |
AE_SeriousnessDisabling Indicator |
Whether the adverse event resulted in persistent or significant disability or incapacity. |
Case Form / Event / <event name> / Seriousness Criteria / Disability |
AE_SeriousnessCongenital AnomalyIndicator |
Whether the adverse event resulted in a congenital anomaly or birth defect. |
Case Form / Event / <event name> / Seriousness Criteria / Congenital Anomaly |
AE_SeriousnessOtherIndicator |
Whether the adverse event was a medically important condition. |
Case Form / Event / <event name> / Seriousness Criteria / Other |
AE_SeriousnessOtherComment |
The medically important condition indicated by the Other Indicator item. |
Case Form / Event / <event name> / Seriousness Criteria / <Other Comment Text> |
AE_MedicallySignificant Indicator |
Whether the adverse event was medically significant. |
Case Form / Event / <event name> / Seriousness Criteria / Medically Significant |
AE_SubjectDroppedFromStudy Indicator |
Whether the subject dropped out of the study because of the adverse event. |
Case Form / Event / <event name> / Diagnosis / Dropped From Study Due to Event |
AE_RelatedToStudyConduct Code |
Whether the adverse event was related to a study procedure. |
Case Form / Event / <event name> / Diagnosis / Related to Study Conduct? |
AE_ReceivedTreatmentCode |
Whether the patient received treatment for the adverse event (Yes, No, Unknown). |
Case Form / Event / <event name> / Diagnosis / Treatment Received |
AE_SubjectHasPriorHistory Code |
Whether the patient had experienced the adverse event in the past (Yes, No, Unknown). |
Case Form / Event / <event name> / Diagnosis / Patient Has Prior History |
AE_LackOfEfficacyIndicator |
Whether the adverse event indicates a lack of efficacy of the study drug. |
Case Form / Event / <event name> / Diagnosis / Lack of Efficacy |
AE_DiseaseProgression Indicator |
Whether the adverse event caused the disease to progress. |
Case Form / Event / <event name> / Diagnosis / Progression of Disease |
AE_AdverseDrugWithdrawal ReactionIndicator |
Whether the adverse event was caused by withdrawal of the drug. |
Case Form / Event / <event name> / Diagnosis / Adverse Drug Withdrawal Reaction |
AE_InfectionIndicator |
Whether the adverse event resulted in an infection. |
Case Form / Event / <event name> / Diagnosis / Infection |
AE_CaseNarrative |
An item from an AE form that needs to appear in the narrative for the case in Argus Safety. If multiple AEs are selected using the dynamic grid functionality, the item mapped will appear for each AE selected in the order it was selected in the dynamic grid. This information will appear in the case narrative in Argus Safety before the items on the SAE form mapped at the Safety_Case level.
Case Form / Analysis / Case Analysis / Narrative |
