Map two or more dynamic grids selecting adverse events from one Adverse Events form
- If you need to have two or more dynamic grids selecting adverse events from an Adverse Events form, create a new data set assigning an alias prefixed with DSREboPatientMhxEp_.
For example, if you want the site user to select AEs that should go over as part of the case to Argus Safety in one dynamic grid but want another dynamic grid in the form to allow the site user to select AEs to go over as medical history, you should copy the Subject_MedicalHistory data set to a new data set. Map the items in this new data set to the AE form.
- Designate a column in one of the dynamic grids that contains the adverse events to be included in the safety case.
This column should exist only in this dynamic grid and it needs to be mapped to the SafetyCaseAEDynamicGrid data series. For example, in the use case where the second dynamic grid would be selecting AEs to send as medical history, you should pick an item from the AE form that would not be part of the medical history dynamic grid.
- •One item from each dynamic grid, except for the AE dynamic grid, should be mapped to the RelatedDynamicGrid data series.
