Custom Dimension Labels - Select Codelist dialog box—Option descriptions
In the Custom Dimension Labels - Select Codelist dialog box, you select or create a codelist for the labels for custom data dimensions created with a data set.
Note: The dialog box appears when you define a custom data dimension and then click the button in the Codelist Lookup column.
Option |
Description |
[Codelist drop-down list] |
List of available codelists. |
New |
Create a codelist. |
Code |
List of codes for the selected codelist. |
Label |
List of labels for the selected codelist. |
Use only listed labels checkbox |
Indicates whether users are required to choose from the custom dimension labels that you provide, or if they can provide their own values.
Note: If you select Use only listed labels, the codelist must have at least one codelist item. |
