Deployment ConfigFile options
As an alternative to entering deployment options at the command line or in a script, you can include the options for executing a deployment package in a configuration file referenced by the /ConfigFile command-line option. The configuration file is in XML format.
Option |
Description |
<DeploymentData>
xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.phaseforward.com/DeploymentData/2006-04-25" |
<HostName /> <HostUserName /> <HostUserPassword /> <HostSharedDirectory /> <HostSharedDirectoryLocalPath /> |
Reserved for future use. |
<TargetType/> |
INFORM |
<ServerName/> |
Name of the InForm application server. |
<TrialName/> |
Name of the InForm study. |
<UserName/> |
Oracle user name for the study database. |
<UserPassword/> |
Oracle password for the study database. |
<StrictMode/> |
<TrialMode/> |
<TRIDSN /> |
ODBC System DSN for the InForm study. |
<DatabaseConnectString/> |
Connection string for the Oracle instance. |
<TrialStartupMode/> |
<ServerStartupMode/> |
<ForceBASEInstall/> |
<CheckInFormVersion/> |
<ProtocolName /> <ProtocolUserName /> <ProtocolUserPassword /> <DBAdminUser /> <DBAdminUserPassword /> <DataSpace /> <TableSpace /> <UNCHelpDirectory /> <VirtualHelpDirectory /> <WebPath /> <SSL/> |
