Adding and removing a locale
You can add and remove one or more locales at the same time.
To add one or more locales:
- Select System Config.
- In the General section, click the Supported
Locales link.
The Supported Locales workspace appears.
- Click Add (located in the upper-right corner).
The Add Locale dialog box appears.
- Select the checkboxes next to the locales that you want to add to the
supported locales list, and click OK .
The locales are added to the list.
- Click Save.
To remove one or more locales:
Locales link.
- Select the checkbox next to the locale you want to remove, and click
Remove.
The locale is removed from the list.
- Click Save.
Parent topic: Working with supported locales
