Adding, modifying, and deleting a collaboration note type
If collaboration notes that are based on a collaboration note type exist, you cannot delete the collaboration note type.
To add a collaboration note type:
- Select System Config.
- In the Collaboration section, click the Note
Types link.
The Note Types workspace appears, and information about existing collaboration note types appears, followed by a blank row.
- Fill in the fields in the blank row, and click Save.
To modify a collaboration note type:
Types link.
- Select the type that you want to modify.
- For the selected type, click in a field and modify the information as necessary.
- Click Save.
To delete a collaboration note type:
Types link.
- Right-click the type you want to delete, and select Delete Row.
Table 5-6 Note Types workspace - Field descriptions
Field | Description |
Name | Name of the collaboration note type. |
Description | Description of the collaboration note type. |
Parent topic: Working with note types and task types
