Custom Properties workspace—Field descriptions
The fields that appear in the Custom Properties workspace vary according to what you select. You can select a study object, a grouping, or a custom property.
| Field | Description |
| A study object is selected. | - |
| Groupings |
Name of the grouping for the study object. Groupings organize custom properties in the Oracle Central Designer application. |
| A grouping is selected. | - |
| Custom Properties | Name of the custom property created under the grouping for a study object. |
| A custom property is selected. | - |
| Name | Name of the custom property. |
| Data Type |
Data type of the custom property:
| Max Length | Maximum number of characters allowed for the value of the custom property. |
| Description | Description of the custom property. |
| Make Property Visible |
| Use Value List |
The Use Value List grid has the following fields.
Parent topic: Working with custom properties
