Enabling and disabling a dictionary type
A dictionary type must be in the Oracle Central Designer Administrator application before you can enable it.
To make a dictionary type available to be added to a study or library, you must enable it. When a dictionary type is disabled, it cannot be added to any studies or libraries.
If you disable a dictionary type that is used by a study or library in the Oracle Central Designer application, Oracle Central Designer users can view its coding maps but cannot create or modify them.
To enable a dictionary type:
- Select System Config.
- In the Coding section, click the Dictionary
Types link.
The Coding Dictionaries workspace appears.
- Select the Enabled checkbox for the dictionary.
- Click Save.
To disable a dictionary type:
Types link.
- Deselect the Enabled checkbox for the dictionary.
- Click Save.
Parent topic: Working with coding information
