Getting help
The Oracle Central Designer Administrator application provides the following ways to get help:
- Press F1 , and then click the area of the application for which you want more information. A Help window appears with the relevant page displayed.
- Select Help > Central Designer Documentation to open the Oracle Help Center.
Hover Help.
If you hold your mouse pointer over a button, tab, or icon without moving it, a tool-tip appears with a brief description of the item that you are pointing to.
If you need the version of the application, you can view it in the About Central Designer Administrator dialog box. The dialog box also contains copyright information.
