Importing and overwriting dictionary metadata
If a dictionary metadata update is implemented in the Oracle Central Coding application, you will need to update dictionary metadata items in the Oracle Central Designer application. Oracle will provide you with an XML file that you must import to continue using and creating coding maps in the Oracle Central Designer application.
Do not import an XML file unless specifically directed by Oracle, or your coding maps will become invalid.Parent topic: Working with coding information
