Importing, exporting, and deleting system settings
To import system settings from a file:
- Select System Configuration.
- Under General, select System Settings.
The System Settings workspace appears.
- Click Import.
The Open dialog box appears.
- Navigate to the location of the XML file that contains the system settings, and select it.
- Click Open.
If system settings already exist for an InForm release, you must delete the settings before you can import other settings for the same release.
To export system settings to a file:
- From the Settings drop-down list, select the InForm release to export.
- Click Export.
The Export dialog box appears.
- Navigate to the location in which to save the fie, and do the
following:
- Type a name for the file.
- From the Save as type drop-down list, select XML.
- Click Save.
To delete system settings:
- Under General, select System Settings .
- From the Settings drop-down list, select an InForm release.
- Click Delete.
A confirmation dialog box appears.
- Click OK.
Parent topic: Working with system settings
