Predefined functions in the system library
(Optional) Use sections to add and organize related content if another section heading is needed.
Classification Function Purpose
Clinical Functions
_CalculateBMI
Calculates the Body-Mass Index, based on height and weight.
_CalculateBSA
Calculates the body surface area.
_CalculateWaistHipRatio
Calculates the waist-to-hip ratio.
Clinical Validation Functions
_CheckPatientInitials
Checks the format of the subject initials.
Date Manipulation Functions
_CalculateDateTime
Calculates a new date and time by adding an interval to or subtracting an interval from another date and time. The interval is based on a date part, for example, a number of days.
_CompareDates
Compares two date times to determine whether the first date time is less than, equal to, or greater than the second date time.
_CompareDatesWithRange
Compares two date times to determine whether they are within a specified range of each other.
_GetCurrentDate
Returns the current date and time on the Oracle Health Sciences InForm server.
_GetDateDifference
Returns the number of units between two specified dates, based on the requested date part.
_NormalizeDate
Normalizes a date based on the specified template.
_NormalizeDateToMax
Normalizes UNKNOWN or EMPTY date time parts to the maximum values for those parts.
Date/Time, Float, Integer, or Text Array Comparison Functions
These functions take different parameters depending on the data type of the value to which you are comparing the values in the array.
_Count
Counts the number of occurrences of a specified value in an array.
_IsValueGreaterThanArray
Checks whether a specified value is greater than all values in an array.
_IsValueGreaterThanOrEqualToArray
Checks whether a specified value is greater than or equal to at least one of the values in an array.
_IsValueInArray
Checks whether a specified value is equal to one of the values in an array.
_IsValueLessThanArray
Checks whether a specified value is less than all values in an array.
_IsValueLessThanOrEqualToArray
Checks whether a specified value is less than or equal to at least one of the values in an array.
EDC
GetScreeningNumber
Returns the screening number of the subject in the Oracle Health Sciences InForm application.
GetSiteLocale
Returns the locale of the study site, such as en-US or ja-JP.
GetSiteMnemonic
Returns the mnemonic (abbreviated site name, specified in the Admin area of the Oracle Health Sciences InForm application) for the site of the current subject.
GetSiteTime
Returns the current time at the data-entry site.
GetSubjectNumber
Returns the number of the subject in the Oracle Health Sciences InForm application.
GetTrialName
Returns the name of the trial in the Oracle Health Sciences InForm application.
GetUserName
Returns the name of user who is currently logged in to the Oracle Health Sciences InForm application.
Randomize
Returns a drug kit number based on the randomization type and the sequence and drug kit numbers stored in the randomization source database on the Oracle Health Sciences InForm host computer.
Rule Event Functions
_SaveToDb (String, String)
Determines whether to send data to the Oracle Health Sciences InForm Publisher queue.
