Values[]
Characteristic | Description |
Icon |
Availability |
An item that is a child of one of the following:
Return type |
Description |
Returns an array of values from item instances that are part of a repeating study event, repeating form, or repeating section. |
Included in the array |
Values of undeleted items. An item is undeleted if someone has provided a value for it, and the form or section that contains the item has not been deleted. |
Not included in the array |
Example |
A study contains the following repeating forms, which contain the
AEDate item:
When you use this property, the following instances are
returned:
Notes |
Note: Values[], AllValues[], Objects[], and AllObjects[] all return an array of data. Consider the following scenarios when deciding upon the property to use:
Additionally, consider that the following CurrentIndex properties
are also available:
Parent topic: Rule model properties for data series
