System requirements: Application servers
| Feature | Application server requirement |
Operating system |
You can install on an English (United States) operating system only. |
Processor |
Minimum: 2.0 GHz or higher Recommended: Multiple processors, each 2.0 GHz or higher |
Memory |
Minimum: 8 GB Recommended:16 GB |
Disk space |
In addition to the space required for the operating system:
Connectivity |
100/1000 NIC |
Display |
Software |
Windows components:
Oracle client components:
Services |
The Distributed Transaction Coordinator service must be running. The service provides transaction support for Oracle Central Designer database operations. |
Parent topic: Hardware and software requirements
