Previous Topic
Next Topic
Book Contents
Properties in the Rule Test Cases dialog box
The following properties appear in the Test Properties tab, which you can select in the Design tab of the Rule Test Cases dialog box.
When you point to a component of a test case, its properties appear.
Property
Description
Properties for test names
Ignore test
When False, the test case is run. When True, the test case is not run.
Rule name
Name of the rule or global condition.
Rule type
Type of rule (data-entry rule, global condition, or workflow rule).
Properties for item names—Item Settings grouping
Notes:
If the item is repeating, the grouping is called Repeating Item Settings.
Not all properties are available for all types of items.
Codelist choices
Indicates the type of the codelist. Expand the property to view the code and label for each codelist item in the right column.
Notes:
  • The numbers in the left column are for ordering purposes only and do not necessarily correspond to the codes for the codelist items.
  • If a codelist subset is selected for the codelist instance, only the codelist items in the selected subset appear.
Codelist type
The type of codelist on the item, such as float or integer.
Float length
Length of the float item.
Float precision
Precision of the float item.
Item object path
Path of the item in the context of the rule scope.
Object RefName
RefName of the item.
Note: Oracle recommends that you do not update the Object RefName.
Object Title
Title of the item.
Repeating objects
List of repeating study objects that are in the item's path, including the type of study object (such as form or section).
Properties for item names—Test Settings grouping
Ignore test
Properties for expected results—Repeating Objects grouping
Repeating Form Index
Repeating Section Index
Repeating Event Index
Properties appear in this section when an item path contains a repeating study object. For example, if the only repeating study object in the item path is a section, only Repeating Section Index appears.
The number of the repeating instance that you are testing.
Properties for expected results—Test Settings grouping
Ignore test
Default: False.
Item object path
Rule action type
  • Data-entry rules—Value, Query, or Email.
  • Global conditions—Condition.
  • Workflow rules—NextStep.
Rule name
Rule type
Send Feedback
